Installed (recommended) custom symbols, how do I install or import the default walls?
clean install walls reinstalling
#1 Tom McConnell
Tom McConnell
  • 279 posts
Posted 15 June 2023 - 07:30 AM
I installed SP2024 and used (recommended) custom symbols and settings.
Only my custom walls installed and none of the SP clean install walls installed.
I assuming this followed through for other items.
How do I install or import the default walls, like if you did a clean install, without reinstalling SP?
SoftPlan+ 2021
OS - Windows 11.0 Pro 64 Bit
MB - ASUS ROG Strix X570-E
3Dconnexion CadMouse
#2 Sam Morgan
  • 936 posts
Posted 15 June 2023 - 02:20 PM
I called SP to get help doing this since I've never been able to install and get my system settings to carry over.  I'll see if I can remember the process.
in your 2022 go to system options--->system options--->archive--->select everything you want to bring over then hit backup.  I selected everything when I did it so it would bring in my walls, symbols, settings, etc.
In your 2024 go to system options--->system options--->archive--->restore.
#3 Richard Rubinski
  • 693 posts
Posted 15 June 2023 - 03:28 PM
You can open a project that has all of your wall and save it as a Drawing Template, save it to System, then use that template on your new projects instead of the Default Template.
#4 Tom McConnell
Tom McConnell
  • 279 posts
Posted 19 June 2023 - 08:07 AM
I got my custom setting installed fine, however non of the "clean Install" settings are there.
I am trying to Merge (install) the settings as if I did a clean install.
SoftPlan+ 2021
#5 Tom McConnell
Tom McConnell
  • 279 posts
SoftPlan+ 2021
  • 5,298 posts
Posted 19 June 2023 - 11:28 AM
I don't think you can restore the default options with your custom install.
#7 Richard Rubinski
  • 693 posts
Posted 19 June 2023 - 11:43 AM
Backup 2022 and restore it to 2024.
Also tagged with one or more of these keywords: clean install, walls, reinstalling
