Siding Missing
siding
#1 Steven Wohlgemuth
Steven Wohlgemuth
  • 93 posts
  • LocationNew Brunswick Canada
Posted 18 June 2020 - 01:31 PM
I need help with fixing this siding that is missing. Is there a simple way to do it? I can extend the wall in past the little roof but then i have siding inside!!
#2 Mark Petri
  • 1,874 posts
Posted 18 June 2020 - 02:18 PM
Add a small wall of just siding or siding and sheathing in that area and set the bottom to slope to the lower roof and top to align with the wall to the right of it (in the picture).
#3 Jon Churchill
Jon Churchill
  • 516 posts
  • LocationThe Oaks, Australia
Posted 18 June 2020 - 05:08 PM
Steven,
Have you tried adding a roof plane. Yes sounds a bit strange adding a roof plane to a wall, but if you are just wanting to fill the gap in 3D all works well. A roof plan can be drawn on any surface, it is a triangle only. Just set the roof material to something that is not used elsewhere on the drawing and set the texture as required. You can also use the texture offset to align the cladding.
If necessary the position of each corner can be edited in roof mode, but it easier to just draw it in 3D again if incorrectly positioned.
Jon
#4 Steven Wohlgemuth
Steven Wohlgemuth
  • 93 posts
Posted 20 June 2020 - 08:01 AM
Thanks Both Of those Solutions work!
Also tagged with one or more of these keywords: siding
