Board and Batten Alignment
surface board and batten alignment siding 3d rendering levels pattern
#1 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 31 May 2022 - 01:32 PM
Is there any way to get the board and batten surface material to match up correctly between levels?
Attached File  Siding problem.jpg   92.16KB   3 downloads
It's lined up perfectly, but for some reason the pattern doesn't quite match.
Attached File  Siding Break.jpg   28.22KB   2 downloads
Oddly enough, one side of the house is correct.
Attached File  Good Wall.jpg   63.39KB   2 downloads
#2 Joseph Smith
  • 889 posts
Posted 31 May 2022 - 02:03 PM
check your wall def. siding material type of the one not aligning, the siding MUST be identical siding callout.
if still an issue possibly don't use board/batton but instead use siding A.  i had the same problem when using log siding a few weeks back....the log didn't match so i changed to Siding A for all the log stuff and it worked!
  • Wendall Hilty likes this
  • 5,454 posts
Posted 31 May 2022 - 03:12 PM
Try ... PERFORM ITEM CLEANUP (From the COMMON tab in the EDIT menu) on both of the affected walls
#4 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 31 May 2022 - 03:23 PM
I opened the project again to try your suggestions and to my surprise the problem has resolved itself. I suspect that "Item Cleanup" would have taken care of the problem.
Attached File  House.jpg   45.03KB   0 downloads
#5 Mike Adams
Mike Adams
  • 294 posts
Posted 06 June 2022 - 03:22 AM
More times than I can count,the same has happened.  I think my issue is I overwhelm the program with too many things at once.  Close it up, work on something else, come back later in the day and it resolved itself.
Also tagged with one or more of these keywords: surface, board and batten, alignment, siding, 3d, rendering, levels, pattern
