Collage of exterior materials
exterior materials collage
#1 Edward Shannon
Edward Shannon
  • 157 posts
  • LocationDes Moines, Iowa
Posted 20 October 2020 - 09:08 AM
Is there  a way to create different materials in the wall plane as seen in 3-D?  I understand I can create different walls types with siding A, B, C, etc.  However I have a design where materials will be overlapping horizontally and vertically.  I am wondering if there is a way to accomplish this is 3-D?
#2 Philip Frank
  • 578 posts
Posted 20 October 2020 - 10:03 AM
Use the "Transition" function of the wall?
#3 Edward Shannon
Edward Shannon
  • 157 posts
Posted 20 October 2020 - 10:13 AM
Thanks Phil - If I understand, this will create a horizontal transition for that particular wall type?  I am looking to do more variety.  create "patches of material that wrap beneath windows.  I am wondering if there is something that can be used in the live elevation mode?  Here is an example
#4 Heath Foster
Heath Foster
  • 177 posts
Posted 20 October 2020 - 02:36 PM
Some have had success using wallpaper on the exterior and changing the size and height offset, or perhaps using solids...
  • Edward Shannon likes this
#5 Thomas Roman
Thomas Roman
  • 366 posts
  • LocationSacramento, CA
Posted 20 October 2020 - 07:34 PM
Yes.. I'm one of those that uses the Interior Mode tools on exterior surfaces...
Wallpaper, or paint, is quick way to get, say, three different siding colors.. or easy way to change the exterior material at the peek of a gable..
#6 Thomas Roman
Thomas Roman
  • 366 posts
Posted 20 October 2020 - 10:08 PM
To get that grid type trim pattern I see on your PDF, onto a model, I might use "bands" for the horizontal trims, and perhaps use solids for the vertical trims..
Also tagged with one or more of these keywords: exterior, materials, collage
