Problem with Imported 3D Warehouse Models
3d symbols 3d textures sketchup import
31 replies to this topic
#1 Galen Doscher
Galen Doscher
  • 17 posts
Posted 09 November 2015 - 06:03 AM
I have been using 3D Warehouse as a resource for 3D models to use in my Softplan models.  Recently, I am finding that the textures mapped to the symbols are not scaling properly, and can't be adjusted as with other symbols in Softplan.  For instance, a picture frame imported into Softplan shows up not with the picture scaled to the canvas, but tiled with so many tiles that it looks like a solid color.  What is causing this and how do i fix it?
Thank you,
Galen
Posted 09 November 2015 - 07:11 AM
Can you give us a location for the sketchup model?
#3 Galen Doscher
Galen Doscher
  • 17 posts
Posted 09 November 2015 - 09:08 AM
https://3dwarehouse....ec-5b5224a0e016
This is one that some of the images don't scale correctly...
Here is another one...
https://3dwarehouse....244646af6cdd10a
but it happens with many different models... for instance the white one in this set...
https://3dwarehouse....3590266b46c1c56
Posted 09 November 2015 - 11:40 AM
Is it happening with any particular texture OR all of them.
If you have adjusted a texture, I've noticed in the past that it stays adjusted. Resetting back to the original is more difficult. Bear in mind that on the textures, the correct scale is 1 pixel = 1/16".
#5 Galen Doscher
Galen Doscher
  • 17 posts
Posted 17 November 2015 - 11:45 AM
It seems to only happen to some of them, but I haven't been able to determine any pattern, but I don't really know what I am looking for.  The textures that the scaling seems to be screwy on don't accept any adjustments to the textures parameters, the parameters can be changed, but it doesn't seem to have an effect on the visual.  Did you find the models do the same thing for you?  or did they work just fine?
Posted 17 November 2015 - 12:20 PM
Sorry Galen, I have the same problem that you do. The textures (photo's) inside the pictures don't come in at the correct scale - or at least most of them don't - the European Robin in the centre picture was fine ... and I haven't been able to figure out what the issue is. The white sculpture (whatever it is) doesn't seem to be a problem - Although the white comes in as three separate colours - I've recoloured this to make it obvious.
#7 randolph cohn
Posted 17 November 2015 - 03:45 PM
not sure this is your issue
but
what format are you using ?
if 3ds,  try a dwg or dxf
and visa versa.
if none of this works,
call up tech,  they usually know how to fix problems.
SoftPlan Technical Support
Telephone: 519-886-9750  canada
if you have softplan PLUS,  there's a free 800 number to call tech
on your START PAGE (when softplan first opens up.
Posted 17 November 2015 - 04:16 PM
They are imported sketchup (.skp) files, Randy. Just run through the wizard. So doesn't have an intermediate format.
#9 Brent Greener
Brent Greener
  • 83 posts
Posted 01 June 2017 - 05:04 PM
Was their ever a fix for this. I noticed this always seems to happen on my SketchUp imports and right now I am looking at the same problem on the Pediments for interior trim, and those symbols came from Soft Plan.
#10 Brent Greener
Brent Greener
  • 83 posts
Posted 11 October 2017 - 08:14 AM
Just created a custom column in Sketchup 2017 and the textures look like crap. Can not scale them or anything, none of the setting effect how it looks. Anyone ever got anywhere with this?
#11 Keith Almond
Posted 11 October 2017 - 08:53 AM
Don't texture it in Sketchup. Add the texture in the wizard.
#12 Brent Greener
Brent Greener
  • 83 posts
Posted 11 October 2017 - 09:18 AM
That is what I am doing, I just use solid colors in Sketchup
#13 Brent Greener
Brent Greener
  • 83 posts
Posted 11 October 2017 - 11:06 AM
I remade it using the default texture in Sketchup on all surfaces and it still does the same thing.
I tried Support + and got the following "We're unsure of how to stop a surface from being mapped in Sketchup. I would recommend contacting Sketchup support for further assistance."
Then they closed the ticket right away....
Seems if it is a supported feature of Soft Plan they should have some idea of how to make it work.
#14 Mark Petri
  • 1,874 posts
Posted 11 October 2017 - 12:16 PM
I find that if I want different textures on models I import from SketchUp that the best thing to do is put any different textures on the model in SketchUp (just to represent the different textures I will want in SP). Then, if I am concerned about wood grain going the correct direction, I also adjust that in SketchUp (there are some great plug-ins).
Then, I always export a 2D plan as a DWG that I import and clean up in SP to look how I want it. I also export a 3D 3DS file from SkecthUp, which I save to the project and copy into my 3D symbols folder in SoftPlan. I do it this way because the wizard often screws up the look if I import it directly.
In the Symbol edit menu, I just import the 2D drawing as a symbol, then link it to the 3D symbol I saved to the SP 3D Symbols folder of my choosing. Then, I click on the textures to populate the different textures (just click on them, but I don't change anything). Then when I save the symbol it is set. When I use it in a model I then click on textures I want to use and color it accordingly (especially when concerned about wood grain). If not, the textures I had when in SketchUp come through as I had it set when importing it.
I am not always successful at getting exactly what I want, but it works well more often than not. I do a lot of timber accents and a variety of other "parts" in SketchUp that I bring into models.
  • Yvon Gonthier likes this
#15 Mark Petri
  • 1,874 posts
Posted 11 October 2017 - 12:18 PM
Of course, curved wood grain surfaces still do not import correctly, because they triangulate in 3D.
#16 Keith Almond
Posted 11 October 2017 - 12:34 PM
3DS files have some issues with textures ... especially when rotating items, as the textures are embedded into the format.
#17 Brent Greener
Brent Greener
  • 83 posts
Posted 11 October 2017 - 01:00 PM
I exported it as a DAE file and that worked fine. Seems Soft Plan has some issue with native SketchUp files they aren't admitting to?
#18 Keith Almond
Posted 11 October 2017 - 01:09 PM
Why do you need to export?
What format do you normally use? Softplan 2018 will use native SKP files in the symbol wizard.
#19 Brent Greener
Brent Greener
  • 83 posts
Posted 11 October 2017 - 01:39 PM
Yes but as I posted above when you apply textures in Soft Plan they are not correct on a SKP file. They look like they are about 2"x2" squares.
Column on the Left is SKP file, column on the right is DAE file. They have the exact same texture applied to them with the same settings.
#20 Yvon Gonthier
Posted 11 October 2017 - 02:45 PM
In your 1rst column, did you try to adjust (increase) the size of the texture (Distance>Horizontal & Vertical)
Also tagged with one or more of these keywords: 3d symbols, 3d, textures, sketchup, import
