In your 1rst column, did you try to adjust (increase) the size of the texture (Distance>Horizontal & Vertical)
Yes none of them have any effect on the texture at all as I stated before. Same with rotate, and scale, no effect.
Posted 12 October 2017 - 08:30 AM
It is super nice that we can use SketchUp along with SP. It'd be even better if the programs worked better together though. Your column on the right looks good.
I agree, it would be nice to not have to go through the extra step of exporting it to another format.
Posted 12 October 2017 - 09:34 AM
First you would download the model from 3D ware house into SketchUp
Then the way I made it work is in SketchUp go to File-Export-3D Model
In their you save the model as a .dae file to your Soft Plan 3D Symbols folder
Then do as normal in Soft Plan only you link the symbol to the .dae 3d file instead of the .skp ScetchUp file
Posted 12 October 2017 - 10:08 AM
I hadn't noticed it before, as I think most of my models are using solid colours as textures, however, doing a test with some of my own Sketchup drawings, I see them exhibiting the same issues. Thanks for the heads up with the DAE files
Posted 20 July 2018 - 11:41 AM
Brent or Keith,
Does the DAE export work with curved faces and or photomapped textures from sketchup?
I am finding that in the direct sketchup import wizard, models with photomapped or adjusted textures don't even carry their assigned textures over to import - they show up in the download file window, but once downloaded into the wizard.
Galen
Posted 20 July 2018 - 12:23 PM
Tried the DAE approach, must be doing something wrong, or it doesn't work for the models I am importing...
This is what it is supposed to look like:
This is what I get in the symbol dialog box:
All adjustment options in the dialog box don't actually change the properties at all - size, rotation, transparent, auto orient, etc. they have no effect.
Imported directly using the wizard, 75% of the models I want to use have the 2x2 square problem or the textures don't transfer at all, and they can't be adjusted. Now with the DAE import, I don't have 2x2 but I still can't adjust them or get them to show correctly.
How do I get textures to work on these models?
SoftPlan →
SoftPlan version 2020 →
NEED FREELANCERS FOR PER DIEM WORK GREAT PAY!Started by Randy King , 25 Jan 2021 ![]() |
SoftPlan →
General Questions →
PDF import from scale Plans to SoftplanStarted by Robert Kiser , 13 Oct 2020 ![]() |
SoftPlan →
3D printing questions - anyone else 3D printing designs?Started by Mike Smith , 10 Oct 2020 ![]() |
SoftPlan →
Vertical Profile in Wall DefinitionStarted by Mark Petri , 17 Sep 2020 ![]() |
SoftPlan →
Textures in renderingsStarted by Mark Petri , 18 Feb 2020 ![]() |
