Does anyone know why this exterior wall is showing lines at the corners and where the interior walls come in?
Walls.png 5.23KB 2 downloads
Posted 31 January 2023 - 02:02 PM
Maybe check your joint tolerance for each wall? Usually, they do that if the tolerances are less than the 6" default, but I have experienced that problem for corners even when the joint tolerance is not altered a few times. Try using the adjust tool to move the wall slightly over the corner to see if it will disappear. For the other intersections, I am unfamiliar with what you are experiencing.
Posted 31 January 2023 - 04:03 PM
I have this quite regularly with my basement walls. If it's the same issue, filleting them together corrects it.
Posted 06 February 2023 - 10:17 AM
If your walls are the same height and the offset is also the same (both must be true), then try a cleanup first, if that doesn't work, simply adjust the walls slightly to where they meet in the middle. If that still doesn't work, then adjust the join tolerances to 2" and cleanup and readjust if needed.
Guest Area →
Guest Questions →
How to add dashed walls?Started by Jim Casali , 17 Aug 2023 Walls, Demolition, Dashed Lines and 2 more... |
Installed (recommended) custom symbols, how do I install or import the default walls?Started by Tom McConnell , 15 Jun 2023 clean install, walls and 1 more... |
Visible wallsStarted by David Roberts , 18 Mar 2023 invisible, visible, walls |
Guest Area →
Guest Questions →
Basement furring walls & symbolsStarted by Daniel Jackson , 22 Jun 2022 symbols, walls |
Guest Area →
Guest Questions →
Wall DefinitionsStarted by Daniel Jackson , 22 Apr 2022 Walls, Definition, cross sections |
