Wall Lines
Walls Lines Definition 2x6
#1 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 31 January 2023 - 01:45 PM
Does anyone know why this exterior wall is showing lines at the corners and where the interior walls come in?
Attached File  Walls.png   5.23KB   2 downloads
  • Jeremy Plum likes this
#2 Matthew Dunson
Matthew Dunson
  • 256 posts
Posted 31 January 2023 - 02:02 PM
Maybe check your joint tolerance for each wall? Usually, they do that if the tolerances are less than the 6" default, but I have experienced that problem for corners even when the joint tolerance is not altered a few times. Try using the adjust tool to move the wall slightly over the corner to see if it will disappear. For the other intersections, I am unfamiliar with what you are experiencing.
#3 Chris Proost
Chris Proost
  • 143 posts
  • LocationRichmond, VA
Posted 31 January 2023 - 03:07 PM
Are all of the walls the same height and offset?
#4 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 31 January 2023 - 03:15 PM
The wall tolerances are still at 6". No amount of moving or adjusting removes it. The walls are all the same height and offset.
  • 5,454 posts
Posted 31 January 2023 - 04:03 PM
I have this quite regularly with my basement walls. If it's the same issue, filleting them together corrects it.
#6 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 31 January 2023 - 04:08 PM
Thank you. I tried it but that wasn't successful either.
#7 Tim Stockton
Tim Stockton
  • 354 posts
  • LocationWichita, KS
Posted 06 February 2023 - 10:17 AM
If your walls are the same height and the offset is also the same (both must be true), then try a cleanup first, if that doesn't work, simply adjust the walls slightly to where they meet in the middle.  If that still doesn't work, then adjust the join tolerances to 2" and cleanup and readjust if needed.
Also tagged with one or more of these keywords: Walls, Lines, Definition, 2x6
