I recently decided to get better familier with my SoftPlan 14 3D capabilities. To say its a work in progress is an understatement to say the least. To cut to the chase I've fooling around trying to work on some winter Renderings when I noticed my Rendering and Texture look exactly the same. I will attach each JPEG file for comparisons. Are they suppose to look the same? I always thought that the Rendering was a much more detailed then the textured but I'm not seeing it. Help!
3D Rendering & 3D Texture- is it my settings or my computer?
Posted 15 February 2015 - 11:02 AM
All of the modes can be set exactly the same so the difference is how each is set.
Texture mode default is to render with GPU and Render is default to CPU Ray Trace
The biggest difference between raytraced and GPU is how accurately shadows, reflections, Depth Relief and light are rendered.
In this case you are not using the sun to cast shadows or reflections in glass etc. so there is not much difference.
Or you may have inadvertently set both modes to the same setting.
Other differences is GPU render allows you to use lines
CPU render allows you to use hard shadows
Overall though a pretty good first effort
You could add just a very little amount of sun to give it a little more definition and maybe warm the lights to make it more welcoming.
The best thing to do is experiment with different settings to see how each effects the rendering.
-Chris
Posted 15 February 2015 - 12:49 PM
thomas
you can get some nice winter renderings using snow texture with site terrains.
hard to tell you how to do site terrains on a splash post.
if you have softplan (+), check out their tutorials on the "start page"
and also go to softplantuts.com > bill has done a great job with learning
softplan with tutorials.
v10 to future 2016+
Posted 15 February 2015 - 01:24 PM
Thanks Chris! Yes at some point I changed the settings in Render to GPU. I reset it back to CPU and now I can see the difference. I remember changing it as I thought it Regenerated faster but didn't realize it changed it to Textured as a result. Thank for the help and I look forward to not seeing Newbie over my head in future post.
#5
Posted 15 February 2015 - 01:29 PM
Wow Randy! after reading your post I realized I could change the shingles texture to snow texture. I haven't tried it yet so I'm just assuming at this point but after seeing the rendering you attached I'm confident at some point I'll get the winter theme figured out. I've also read somewhere on Spline (Facebook) that Sketchup is a great tool to use as well. I'll try to master SoftPlan 14 before venturing down that path.
Also tagged with one or more of these keywords: Renderings
SoftPlan →
SoftPlan version 2020 →
Textures in renderingsStarted by Mark Petri , 18 Feb 2020 ![]() |
SoftPlan →
SoftPlan 2018 →
Custom 3D Mode Options - Possible??Started by Mark Beard , 17 Jan 2018 ![]() |
SoftPlan →
General Questions →
Softplan rendering help wanted - 2016Started by Mike Smith , 05 Jan 2016 ![]() |
