Add Drywall does not account for floor sill plate
Add Drywall Sill Plate Hole
#1 Tom McConnell
Tom McConnell
  • 277 posts
Posted 13 September 2019 - 07:34 AM
The "Add Drywall" to "Hole" in a wood truss floor system with "Sill Plate" does not account for the "Sill Plate" and leaves a gap.
Anyone else?
Attached File  SP09.jpg   162.82KB   0 downloads
SoftPlan+ 2021
OS - Windows 10.0 Pro 64 Bit
MB - ASUS ROG Strix X570-E
3Dconnexion CadMouse
#2 Derk Burgers
Derk Burgers
  • 79 posts
  • LocationSioux Center, Iowa
Posted 13 September 2019 - 08:05 AM
Anyone else?
Is there a reason you're using a sill plate on the second story? In my area the second story trusses bear directly on the first floor walls.
  • Chris Proost likes this
#3 Tom McConnell
Tom McConnell
  • 277 posts
Posted 13 September 2019 - 09:09 AM
Sill is on top of first floor wall under second floor system.
First floor is block. Engineer wants it that way.
  • Derk Burgers likes this
SoftPlan+ 2021
#4 Steve and Carla Farnam
  • 655 posts
Posted 13 September 2019 - 10:54 AM
Tom you may be able to edit the plate definition and add sheetrock inside
or create a wall that is a plate with sheetrock inside and outside being whatever
finish material you are using and replace the sill plate with the new wall.
  • Gary McKeon likes this
Also tagged with one or more of these keywords: Add Drywall, Sill Plate, Hole
