Could somebody please advise me on how I can add the Pole Barn Wall to my Wall List? I've tried everything according to the directions and the wall will NOT show up in my list at all! Thank you!
Posted 16 January 2020 - 06:42 AM
If you did create it in the System Options then you can get it into your drawing by resetting the drawing to the system wall library.
Go to Drawing Options>Drawing Options>Define Wall. On the right you will see 'Reset To Drawing Template'. Make sure the radio button for system is active and click 'Reset".
The wall should now be in your drawing wall list.
Posted 16 January 2020 - 11:10 AM
Easier (SAFER - in case like me you create custom walls in drawings), you go to the system wall library, EXPORT the wall you just created. Then in the drawing library, IMPORT the same wall.
- Steve and Carla Farnam and Michael Roman like this
Reply to this topic
Also tagged with one or more of these keywords: Walls
Guest Area →
Guest Questions →
How to add dashed walls?Started by Jim Casali , 17 Aug 2023 Walls, Demolition, Dashed Lines and 2 more... |
Installed (recommended) custom symbols, how do I install or import the default walls?Started by Tom McConnell , 15 Jun 2023 clean install, walls and 1 more... |
Visible wallsStarted by David Roberts , 18 Mar 2023 invisible, visible, walls |
Wall LinesStarted by Wendall Hilty , 31 Jan 2023 Walls, Lines, Definition, 2x6 |
Guest Area →
Guest Questions →
Basement furring walls & symbolsStarted by Daniel Jackson , 22 Jun 2022 symbols, walls |
