PDF Quality Problems
Pdf printing exporting quality messy
21 replies to this topic
#1 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 27 April 2022 - 08:31 AM
Does anyone else ever have any problems with messy pdfs like shown on this roof? I'm using pdf Redirect to export these files because I do not have Softplan+.
Attached File  Capture.PNG   788.41KB   1 downloads
It usually occurs when the paint adapts to sharp pointed corners. I've messed around with the quality settings to no avail.
Is there any way to avoid this or is there a better pdf printer available?
#2 Rick Kingsbury
Rick Kingsbury
  • 171 posts
  • LocationSpearfish, SD
Posted 27 April 2022 - 09:02 AM
I use CutePDF Writer sometimes when the Softplan pdf does not work properly.
  • David Franz likes this
#3 Sam Morgan
  • 938 posts
Posted 27 April 2022 - 09:55 AM
I use adobe and have zero problems with quality
  • Stephan Page likes this
#4 Stephan Page
Stephan Page
  • 95 posts
  • LocationMaine
Posted 27 April 2022 - 10:00 AM
I also just print to Adobe with no issues.
Posted 27 April 2022 - 10:03 AM
Like Rick, if I have to, I use CutePDF Writer. Never seen PDF's come out like that.
  • Rick Kingsbury likes this
#6 Bill Wimberley
Bill Wimberley
  • 622 posts
  • LocationSan Angelo, TX
Posted 27 April 2022 - 10:48 AM
I use SoftPlan's Export PDF by right clicking on the Plan Set. In literally thousands of PDF's created this way I have never had even one problem. They always come out perfect.
  • Attached File  PDF.jpg   66.96KB   0 downloads
  • Jim Johnson and David Zawadzki like this
#7 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 27 April 2022 - 11:35 AM
I think you need to have Softplan+ to gain access to that feature. In any case, I don't have it.
#8 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 27 April 2022 - 11:51 AM
I downloaded cute pdf and it came out looking exactly the same as the one above. I'm rendering it at 600 dpi on an ARCH D page.
#9 John Patterson
John Patterson
  • 187 posts
  • LocationPowell Ohio
Posted 27 April 2022 - 12:58 PM
It looks like some bleeding is going on between the paint area's!
  • Wendall Hilty likes this
#10 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 27 April 2022 - 01:29 PM
Here is a pdf I exported with cute pdf. I can't believe that no one else has this problem. It has been happening to me from the start.
Attached File  Softplan.pdf   845.95KB   60 downloads
#11 Keith Almond
Posted 27 April 2022 - 01:37 PM
Wendall, can you post the original *.spd file ... just that file ... if possible. (Spd isn't a valid attachment, so add it to a zip file). So that we can investigate further.
#12 Henry Buckner
Henry Buckner
  • 342 posts
Posted 27 April 2022 - 01:45 PM
It's possible that the ridge caps are distorting the roof planes. That's happened to me in the past.
#13 Gary Wicklund
Gary Wicklund
  • 200 posts
  • LocationDuncan BC Canada
Posted 27 April 2022 - 07:24 PM
You only need the ReView module, 395$
#14 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 28 April 2022 - 05:29 AM
Here is a zip file with the front elevation.
Attached File  FRONT ELEVATION.zip   248.43KB   16 downloads
#15 Richard Rubinski
  • 698 posts
Posted 28 April 2022 - 08:00 AM
One is printed from Review and the other from Cutie. I don't see a difference.
#16 Richard Rubinski
  • 698 posts
Posted 28 April 2022 - 08:04 AM
It looks messed up when you look at it online, but if you download it and save it to your computer then open them they look good. I attached a screenshot from the pdf.
#17 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 28 April 2022 - 08:34 AM
I can see some of those lines even when I download the pdfs although they do look better than mine. I wonder if the computer being used has an effect on how the pdf renders and displays.
#18 Richard Rubinski
  • 698 posts
Posted 28 April 2022 - 11:32 AM
I’ll have to look how I have cutie setup
#19 Don Gibbons
Don Gibbons
  • 375 posts
Posted 28 April 2022 - 03:58 PM
When I don't export PDF through Plan Sets, I use Print to Microsoft PDF and have no problems.
#20 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 28 April 2022 - 08:08 PM
The thing about Microsoft PDF is that it doesn't include the ARCH series of paper sizes.
Also tagged with one or more of these keywords: Pdf, printing, exporting, quality, messy
