When I insert a tub, shower, or a few other types of symbols, that are generally placed between two walls, I have issues with them moving.
For instance, I rough draw a floor plan, then dimension, and adjust dimensions as needed.
Then I insert symbols as needed. So a 60" tub between two walls that are 60" apart. That's fine.
However, if I need to change one of the walls to a 2x6 or just need to make a room bigger/smaller, I edit the dimension, and the tub moves with the wall. Then I have to go back and move the tub back where it belongs.
How do i stop this from happening?
I turn off the "attach" button first and that doesn't seem to work either.
