Precision for Dimensions
Dimensions
#1 Troy Walsh
Troy Walsh
  • 15 posts
Posted 01 March 2023 - 03:26 PM
Hi;
New user here.  I noticed when dimensioning since I updated to 2022, it has dimensions to the precision of 1/32th.  Not sure In the USA but here in Canada no framer/ builder ever uses that close of precision.  LOL LOL.  I can't seem to find the option to adjust the precision to 1/16th.  Is there an option for this ?.  Thanks for help, much appreciated ...
Troy
#2 Joseph Smith
  • 853 posts
Posted 01 March 2023 - 03:40 PM
You can edit an individual dimension and round as required....then do repeat edit.  Agree, this software shouldn't' even know what 1/32" is.
  • Troy Walsh likes this
#3 John Jones
John Jones
  • Administrators
  • 180 posts
Posted 01 March 2023 - 03:54 PM
If you're seeing small fractional dimensions on your drawing, there is probably something else going on.  The dimension is probably accurate the items being dimensioned may not be where they should be.
#4 Troy Walsh
Troy Walsh
  • 15 posts
Posted 01 March 2023 - 05:07 PM
Thanks guys .. appreciate the feed back ..
#5 Dennis Asher
Dennis Asher
  • 247 posts
Posted 02 March 2023 - 07:46 AM
If you have angles, then you will most likely end up with some 1/32" dimensions.  Also I have noticed that if you are block moving something and unlock your cursor, when you click to drop the item it will not be on the "grid".  If I am block moving something I do it in two operations...up and down, then left and right.
Also tagged with one or more of these keywords: Dimensions
