Length of dimension tails
dimensions arrows
#1 Wesley Penner
Wesley Penner
  • 59 posts
Posted 18 January 2023 - 02:09 PM
Hi
Does anyone know where the length of the dimension tails is controlled? These "tails" show up on dimensions that are too short to harbor the dimension number on its length.
#2 Richard Rubinski
  • 693 posts
Posted 19 January 2023 - 11:49 AM
Under "Arrow Options" do you have checkmark on Show Tails? If so uncheck it or you should be able to control the length.
#3 Wesley Penner
Wesley Penner
  • 59 posts
Posted 20 January 2023 - 06:01 PM
Thanks Richard. That seems to only control the tails of the other dimensions - the ones where the numbers fit between the extensions.
#4 Jim Johnson
Jim Johnson
  • 289 posts
Posted 20 January 2023 - 10:30 PM
Consider using a Slash Arrow.  There just isn't enough space to fit arrows between your extensions and there is not any way that I know of to force them.
  • Wesley Penner likes this
#5 Wesley Penner
Wesley Penner
  • 59 posts
Posted 21 January 2023 - 05:10 AM
While I prefer the look of filled arrows, I see that slash arrows do not have this same uncontrollable tail. Thanks
#6 Ben Ginther
Ben Ginther
  • 141 posts
  • LocationSaskatchewan
Posted 21 January 2023 - 09:55 AM
And, is there a place in System Options that I can adjust the size of Dimension Pointers?
#7 Matthew Dunson
Matthew Dunson
  • 241 posts
Posted 23 January 2023 - 08:25 AM
As far as I am aware, we can only adjust the Dimension/Extension text size, cross over, and start distance in the System, Project, and Drawing settings. Usually when I open a drawing, I right click the extension and adjust the arrow size in the properties. Then I use Draw Select to keep the properties of that set dimension and replace any other ones that require smaller arrows. If there is a way that someone knows how to change arrow size from the system settings, I would like to know because it comes in handy for doing details at small scale.
Also tagged with one or more of these keywords: dimensions, arrows
