I am very new to Softplan, so be easy on me. I have all my walls drawn on my main floor, but when I go to the 3D tab all of my interior walls are not there. Please help!!!!
Posted 28 June 2018 - 07:50 AM
Are they set to "extract in model" on their Edit Wall/Common tab?
Posted 28 June 2018 - 09:51 AM
Make sure also when in 3D that uner Options>Material>Building>Walls that the box for drywall is checked (also make sure that if you click on the drywall texture box, that under Options, the Opacity is set to 100).
Thank you for the help and I will not post in more than one fourm with the same question. I went to my material but drywall has nothing in the material box and I can't find it. Thank you in advance
#5
Posted 28 June 2018 - 10:22 AM
1- Do your interior walls have drywall, see wall definition
2- When in 3D and going into the Material Texture, do you have the Drywall that appears as per image included. When you say it's blank, do you mean that it doesn't appear at all or just that the texture box is white? Mine in the image has a color but only because I give my drywall a base color.
- Brandon Pace likes this
#6
Posted 28 June 2018 - 10:36 AM
It was the wall definition. Thank you for your help, I really appreciate it.
- Yvon Gonthier likes this
Also tagged with one or more of these keywords: Walls
Guest Area →
Guest Questions →
Dimension ProblemsStarted by Jay Jicinsky , 18 Jun 2025 ![]() |
SoftPlan →
SoftPlan 2024 →
Exterior Wall PriorityStarted by Jason Bloomingdale , 03 Oct 2024 ![]() |
Guest Area →
Guest Questions →
How to add dashed walls?Started by Jim Casali , 17 Aug 2023 ![]() |
SoftPlan →
SoftPlan 2024 →
Installed (recommended) custom symbols, how do I install or import the default walls?Started by Tom McConnell , 15 Jun 2023 ![]() |
SoftPlan →
General Questions →
Visible wallsStarted by David Roberts , 18 Mar 2023 ![]() |
