Some Dimensions in Feet Others in Inches?
feet inches dimensions
#1 Kathy Penner
Kathy Penner
  • 82 posts
  • LocationAltona, MB Canada
Posted 17 November 2022 - 01:03 PM
Is there a way to have some dimensions in inches and some in feet and inches in the same drawing?
Thankyou,
Kathy
#2 Richard Rubinski
  • 778 posts
Posted 17 November 2022 - 01:24 PM
edit the dimension that you want to change to inches and select "in inches". Then you can repeat edit the other dimensions that you want in inches. The repeat edit leaves the arrow if the dimension was offset.
#3 Matthew Dunson
Matthew Dunson
  • 270 posts
Hi Kathy, yes there is a way to have some dimensions display only inches or in feet and inches. If you right-click on any dimension and under the Edit properties allows you to check a box to enable "In Inches". There are also settings to display additional text/dimensions, replace existing dimensions, and to change the unit of measure for that dimension under the Edit menu.
#4 Kathy Penner
Kathy Penner
  • 82 posts
Posted 17 November 2022 - 01:56 PM
Thankyou.  Now I wonder why I've never seen that before.
Also tagged with one or more of these keywords: feet, inches, dimensions
