Is there a way to change the underlying degree orientation in drawings? The default orientation of North is the top of the screen, but this is 90 degrees on the degree scale. I know how to change the orientation of North, but this is not what I want to do. When transferring field points from my total station to a site plan drawing, I currently draw a line from the known control point on the drawing and then edit the length and degree of the line. I can then snap a shot point to the end of the line to mark my field observation. It would be much easier to do this if the degree scale were rotated 90 degrees to make North= 0 degrees.
Also is there an easier way to transfer the field points into SoftPlan?
